Are all GLK350 4Matic transmission interchangeable?
car-part.com
There seems to be a lot of them and some with lower mileage.
Might be able to use tranny from C and E class as well.
What happened to the tranny? They are pretty bullet proof.
2012-2013
2010
Even the dealer has different part number. If the matter is just computer programming then it would be easier. Otherwise it would be $$$$ if we have to find out the hard way!
When my transfer case failed, I contemplated getting a used or rebuild tranny but wasn't sure how pairing it with my car might work so ended up rebuilding the transfer case.
You might want to look into rebuilding your transmission. When I was doing some digging, it's a fairly simple design and there are re-builders out there.
