P2643 (soot accumulation) 150km after DPF filter change
- regen at the workshop unsuccessful;
- change differential pressure sensor, regen unsuccesful;
- check inflow airpipes, no success;
- change all inflow gaskets, washed collector case, throttle valve, no succes;
- went to official dealer, changed diff pressure sensor again, no success;
- changed the dpf filter, suceess!
And what do you know? 200kms after dealer the same error is back again. What happens????
Are you sure that the dealer replaced your original DPF or did they just clean it? Personally, I would question whether or not the replacement was completed properly or at all..
