Left-4-Dead GLK 350 Back In Action!
Thank-you for your superb service as an Auto-Crafts educator.
Ray
K-12 Supt (Retd).
I bought the $480 output shaft assembly from them, and installed it within a week or so. A couple weeks later, I'm doing something else under the car and notice that it's developed a disturbing amount of play in one plane (a sure indicator that one of the internal U-joints is loose). I spent two weeks making MANY attempts to get someone - anyone - from Maktrans to contact me, but had no luck.
Well, today I did get a reply. Here's the sum total of their response:
Good day. We cannot help you from a distance, we need a car at our service to carry out a detailed diagnosis. If the part has been installed, it cannot be returned.
So be warned - Maktrans has no useable warranty for anything they sell (perhaps they do take care of their immediate neighborhood in Poland). And based on my 1/1 failure rate, that doesn't bode well.
I hope someone else can come up with a vendor who can supply that output shaft! I dimly remember someone mentioning someone rebuilding their own (seems do-able, at least with the right shop equipment).
I'm nearly ready to see if I can disassemble my original output shaft. I THINK it's pressed together, perhaps more so than I can un-press with my meager 12-ton home press, but it might be worth a try. Then I'd have to figure out where to get new U-joint bearings (with MB not listing the entire shaft, I wonder if they have any reference to the "internal bits" anywhere).
My next step is to knock the bearings off the old unit to see if I can determine just how in the world they assembled this thing.
And FWIW, I did get another reply from the self-described "big guy" at Maktrans. Here it is in its entirety:
Also wondering if there's a way you could just disconnect the front shaft out of the TC into the front diff, thereby eliminating the problem entirely (whilst losing 4wd in the process).
And FWIW, there's really no way to just do a driveshaft delete. I tried it (really, just to move the car around and into my garage), and it just doesn't work. When I took apart the assembly that drives the rear propshaft (aka driveshaft) it was clear why. Basically, our GLKs have non-interruptible FRONT wheel drive, but the power to the rear wheels is through a device that allows for the slight variation in front-to-rear tire diameters / traction loss, etc., and it's just not a solid connection. I suppose it might be possible to reconfigure (read "break") this device so it's permanently locked, but by that point it's really not much more work to just stick in a new front output shaft.
Excellent info, wasn't quite sure how that worked but makes sense seeing as how the "front diff" is actually integrated into the transmission, therefore shares the same lube.
Hoping you'll be able to come up with a fix, as I know the current situation is frustrating.
Just FYI, I couldn't tell much from the video, but I'll look again.
(I have an eye exam coming up next month...)
You should make it your mission to soil their reputation to the far ends of the internet. He must not realize the power of social media. Because of his failure to accept responsibility for your one part, you could potentially cost him hundreds or even thousands of lost sales. Negative reviews are a very strong tool in sales.
I mean you can do what you want as far as going after Maktrans etc, but you simply do Not have a problem here in my opinion.
Maybe 1mm of play in the U-joint is not going to be a problem. But I don't know that because the vendor ignored me for two weeks, then said that they don't do any warranty, and then told me that the problem is in my head. If they had taken a business-like approach to the problem and discussed it intelligently with me, I'd be fine with the situation.
FWIW, my video is not outstanding, but in the first few seconds you can clearly see 1mm or more of movement right at the face of the transfer case. I'm planning to remake a better video, with a runout gauge to show exactly how much play is in the U-joint. And of course, I'll label this one more specifically for those who are looking for info / feedback on that particular replacement part. ;-)
