Bad Pcv valve ?
Old Mar 14, 2023 | 10:37 AM
Mmr1's Avatar
2013 glk 350
Bad Pcv valve ?
A mechanic removed my oil filler cap with motor running , he showed me there was suction pulling it back down, he said it’s a bad PCV valve . Is this true ? I have no smoke or other symptom, oil changed at 5000m but bought used at 37000 miles. It has over 75000 now, I have changed the oil but I don’t know about previous owner. It makes no noise , maybe intake gasket ?
I see nothing in the Glk maintenance manual on even checking the PCV valve going out to 140,000 miles. I’m getting it replaced today.
Old Mar 14, 2023 | 02:05 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Depends. A little suction is a good thing; it helps prevent leaks. A lot of suction is not so good; it can suck dirt past the seals and increase oil consumption.
There should be no positive pressure.
Old Mar 14, 2023 | 02:55 PM
Mmr1's Avatar
2013 glk 350
There isnt much oil consumption , maybe 1/2 quart in 5000 miles.
Old Mar 14, 2023 | 03:14 PM
John CC's Avatar
There' probably a spec for crankcase pressure.
Old Mar 14, 2023 | 08:11 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
No vacuum please ... example :
Old Mar 15, 2023 | 12:13 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
37,000 miles is extremely early for a crankcase vent valve failure on M276. Most go 150,000 miles, some never fail. A noise that sounds like a belt slipping is usually diagnostic of that failure along with a high vacuum at the oil filler cap. If that is the only failure, it does not set the CEL. Maybe yours has just started to fail and hasn’t developed enough vacuum for you to hear the screeching.
Old Mar 15, 2023 | 04:59 AM
Mmr1's Avatar
2013 glk 350
I was not clear, I bought it with 37000 now it has maybe 75000 , could it be intake gasket or something else making vacuum?
Old Mar 15, 2023 | 10:55 AM
Chris1979's Avatar
2011 GLK350
It will absolutely be your PCV valve. Go to FCP euro and buy the package for that. It comes with the 3 cam plugs, oil breather cap, oil drip pan, oil separator, and 2 hoses!!
Old Mar 15, 2023 | 10:58 AM
Mmr1's Avatar
2013 glk 350
I already got the Pcv from fcp, I didn’t see a kit, it should be fine. Thanks
Old Mar 15, 2023 | 02:25 PM
Mmr1's Avatar
2013 glk 350
Approximately how many hours to replace a PVC valve ?
Old Mar 15, 2023 | 03:59 PM
OnlyoneMB's Avatar
2013 GLK 4Matic
PCV
I replaced my wife’s 2013 GLK last year at 60K miles. There was oil in the filter box and this fixed the problem.
Old Mar 15, 2023 | 04:14 PM
habbyguy's Avatar
2011 GLK 350 4Matic
Yeah, a new car is one way to fix a problem... ;-)
Old Mar 16, 2023 | 01:56 PM
Mmr1's Avatar
2013 glk 350
It’s finished , replaced, the hole a hose was attached to was enlarged naturally. No more sucking in the oil cap. Go check your Glk !
Old Mar 16, 2023 | 05:19 PM
John CC's Avatar
It’s filled, the hole a hose attached was enlarged naturally. No more sucking in the oil cap. Go check your Glk !
What does this mean?
Old Mar 16, 2023 | 05:22 PM
habbyguy's Avatar
2011 GLK 350 4Matic
Thanks - I thought maybe I just missed something. ;-)
Old Mar 16, 2023 | 05:47 PM
Mmr1's Avatar
2013 glk 350
I didn’t check autocorrect spelling. Sorry.
Old Mar 17, 2023 | 08:46 AM
John CC's Avatar
Maybe I'm dense, but I still don't get the naturally enlarged hole...
Old Mar 17, 2023 | 10:00 AM
Mmr1's Avatar
2013 glk 350
I’ll look for a photo, the photos you see are the top and it’s bolted down , on the bottom is a about 1” hole with rubber washer that connects to the motor, the rubber washer on the pvc wears, I guess from vibration and a leak develops. I threw the old one away. A poor design and poor placement as it’s like an 6-8 hour job to replace.
Old Mar 17, 2023 | 10:38 AM
Mmr1's Avatar
2013 glk 350
It’s just normal Wear and tear on the gasket, that is in the hole, on the bottom of the pvc. The wear will happen to all pvc and can’t be fixed . I should have worded it differently, and I can’t find a photo of the underside of pvc to show the gasket and hole . A vacuum check of the crankcase is needed to verify it’s bad . I don’t have the vacuum spec. But moderate pull on your oil cap , when you loosen and lift it, with motor running indicates an issue. A mild vacuum is normal. Its something that needs monitoring on old engines.
Old Mar 17, 2023 | 11:36 AM
Mmr1's Avatar
2013 glk 350
This is the bottom view, the big center hole is what connects to the motor, the center is a gasket that fits tight but loosens over many miles . Then it leaks.
Old Mar 17, 2023 | 12:01 PM
habbyguy's Avatar
2011 GLK 350 4Matic
I'm still struggling here... ;-)
Are you saying that the metal (?) hole that the PCV valve "nose" sits in had been worn somehow? Boggles my mind to think how that could happen...
Old Mar 17, 2023 | 12:37 PM
Chris1979's Avatar
2011 GLK350
I see what you mean!! I have a 2011 which is the M272 and it doesn't have the same PCV, similar but not the same. On mine I changed the PCV and the oil drip pan which is to what the PCV attaches to. I also changed the oil separator which sits on top of the engine drivers side along with it's hose. Which by the way when I took off the hose it actually came apart lol. Glad you got that fixed.
Old Mar 17, 2023 | 01:45 PM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
The hose passes through a rubber grommet. The grommet wears/stretches out with age.
Old Mar 17, 2023 | 02:54 PM
John CC's Avatar
Too bad you can't just replace the grommet...
Old Mar 17, 2023 | 03:05 PM
Mmr1's Avatar
2013 glk 350
It’s really to bad it wasn’t made simple like a US 350 v8, a 3$ part and 3 minutes to replace. This thing was insane to get to. Remove the intake , high pressure oil pump and more ! That’s MB .
