Booming sound from the back/Spare tire cover
It's heard from the inside, it seems to be a reverberation/resonance problem of the cabin. From what I've read, the vibrations of the cabin make the air inside vibrate in low frequencies — it is better when I open the windows and/or the sunroof. The booming happens when driving, can be heard best at low speeds where any imperfection on the road is causing the car to vibrate, and when driving faster it seems to be less present, but my ears get tired after a while. The suspension seems to be fine.
I'm wondering what is causing the vibrations? First thing I will have to eliminate is the engine, as I know the engine mounts are bad and need to be replaced.
One thing that I should mention — I've started to hear it after the mechanic replaced the rear shock absorbers. He told me that he had to disassemble half of the trunk to replace the shock absorbers, and after that, the spare tire cover seems to be a little too tight.
That is the cover I'm talking about, I have to use more force to close it and make sure the part in the green circle is properly closed. I think that because that cover is placed tight, it might be squeezing c pillars. Any thoughts? Does anyone know how to disassemble the trunk?
If the noise you mentioned started just after the installation of the new shocks, I'd suggest that the mech didn't get something right.
Otherwise, there are several possible culprits, including bad wheel bearings, differential, bushings, sway bar / links, etc. Without hearing it, it's hard to say.
