2011 GLK350 Headlights
This is my passenger side headlight from engine compartment.
Do Not buy from headlight experts, they are a scam. Check BBB nothing but complaints
I just replaced my first HID bulb in 13 years.
In the description of your kit on the second line it says... (Simple wiring is involved with this kit, just 2 wire splices on each side.) That is not plug and play.
My original bulbs also lasted around 13 years. LED bulbs crap out after a few years.
For replacement bulbs I went with cheaper replacement and they take slightly longer to warm up compared to the originals.
Maybe previous owners switched them out (?). Simply accept what's there and work with it.
Here you go: https://www.youtube.com/watch?v=8LA2zqt1AaY
Beware they are a scam operation! And Citibank mastercard is the same. This is NOT plug and play as promoted, $100s is required to modify headlamp braided cable for installation.
https://www.headlightexperts.com/car...sid=yINyzNFduU
I have this same kind of low beam headlight bulb, bi-xenon with clip and backing plate. I can't for the life of me figure out how to get that bulb out. I can get the clip to unclip from the top. That's easy. Then when I tip it down from the bottom hinge, there's no way to get the bulb out or even more it enough to squeeze connect to remove. When the clip is completely closed, there's no way to squeeze connector and take it off since the backplate has a hook at the bottom that holds and covers that connector in. The main image will show all this. There doesn't seem to be a way to take the clip off from the bottom as each end is bent and when you pull the clip down, it's impossible to remove from plastic holder. Doesn't anyone else have low beam bi-xenon bulbs that are held in this way and were you able to remove it with out having to take a wheel off or or a fender or anything else?
It's crazy because even if i did all that and had more room to access it, the design of the clip is such that i can't see how to get the bulb out without breaking the clip. And that back plate...seems to be connected in a way that you can't remove it without breaking it as well.
Thanks!
Vincent
2011 GLK350 4Matic
Vincent
