Seat heater too hot
The timer works just like the passenger side does (passenger side doesn't get hot like this).
Any ideas how to open the seat back for a visual inspection? Currently I'm manually shutting off the heater.
Many thanks
Not sure about that... higher resistance would reduce current flow and that would result in less heating.
If there was an internal short in the heating element that would cause the bypassed section to go cold, and the remainder to overheat. I think the design would make that unlikely, but anything is possible. Similar technology to a heating blanket.
I’ve never replace a MB seat heater, but many in domestic brands. When I pulled them out, there was always a burned spot on the pad and the iron ribbon element was open at that spot.
On a related note, this kind of failure will never blow a fuse, since the total current is less than normal "max", unless somehow the open circuit moves and finds a nearby ground to play with...
