Rain sensor standby?
Old Dec 11, 2023 | 12:18 AM
Merciful's Avatar
GLK350 2011 RWD
The question is really that simple: does the rain sensor work in car standby, without the key fob inserted?
The story is: I bought a Chinese dashcam, it can be powered from a rain sensor, I asked the seller to put a cable to give it a try and luckily it worked. All is good, but I see that dashcam is on even when I have no key fob inserted and the car ignition is off. I don't know if it's also the same with the alarm set to on, I never tried to stay in a locked car for a long time to observe the camera, but I guess it's the same. However, the seller says it shouldn't be like that and generally rain sensor powers off when the car is locked.
I am concerned about the battery and I do not want 24h recording camera to drain my car battery so I won't be able to start the car.
Anybody can confirm what is the usual behavior of the rain sensor on GLK 2011: does it fade out after switching off the car or it goes to standby and hence keeps power?
I have a California PZEV car if that matters
Old Dec 11, 2023 | 04:04 AM
Mmr1's Avatar
2013 glk 350
It makes no sense for it to be powered when off , I say it’s off.
Old Dec 11, 2023 | 04:39 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
So, have you waited long enough to make a determination? Everything should be "asleep" after 30 minutes or so. That said, if it stays on after the car is off then the wire you're using is probably not switched. The sensor could be commanded off but the power feed still live, sort of like a radio that also has a clock.
Old Dec 11, 2023 | 07:08 PM
habbyguy's Avatar
2011 GLK 350 4Matic
It's not unheard of to supply battery voltage to a circuit, and switch (attach) the ground to energize it. I wish MB had a better service manual so I could look up that circuit in a couple minutes (like the Acura MDX FSM I still reference to answer questions).
Old Dec 12, 2023 | 12:10 AM
Merciful's Avatar
GLK350 2011 RWD
​​​​​​I was waiting in a parked car for 30 min max I would say, and during these 30m the camera was working, I don't know what happened next. That is why I asked here, lol. Maybe somebody already knows the answer so there's no need for me to wait long enough.
Old Dec 12, 2023 | 10:35 AM
John CC's Avatar
I guess I interpreted this to mean you could tell from outside the car that it was on. I think that's what you need to do. The car isn't going to go to sleep if you're still in it, unless maybe if you open and close the door. If you have keyless go you have to get the key outside of the car, too, 10 feet away or so.
Old Dec 12, 2023 | 12:45 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
We mostly use Nest security cameras around our property. Although wireless, they aren't exactly portable.
However, we do have a few Wyze security cameras (wireless) that can be hidden in the palm of your hand, and bought from a local big-box hardware store for $20-25 bucks each.
If you have something similar, you could place the security cam in the GLK, sitting on the center console, pointing at the dash, and check on it *hours* later. That's what I'd do, simply place one of the Wyze cams inside and check on it a couple hours (or more) later
Old Dec 12, 2023 | 01:04 PM
Merciful's Avatar
GLK350 2011 RWD
hahaha, too complicated setup for checking such simple thing. But thanks for the suggestion.
thanks for the hint, never had a guess that car won't go to sleep when I'm inside. Actually by checking camera SD card I see is your suggestion is correct, there were no files recorded throughout the 24h, the storage is empty despite I have plenty of motion on the parking lot. So this seems to be the case: the rain sensor power is switched off after car is locked by key fob.
Old Dec 12, 2023 | 03:18 PM
John CC's Avatar
Get a 12 volt LED and wire it into that circuit and put it somewhere where you can see it from outside.
Old Dec 20, 2023 | 08:57 PM
Merciful's Avatar
GLK350 2011 RWD
My observations up to now: rain sensor works even after I shut the car and lock it from key fob. About 30-40 mins after locking it was still powering the dashcam, I was seeing light indicator through the windshield when standing in front of the car, also I checked the videos folder and there were a lot of videos of my parking lot while it was standing. After 30 min I cannot confirm as I'm too lazy to wait that long.
