GLK250 transmission ISM dealer programming?
I want to swap my 2014 GLK250 Bluetec transmission control unit, I think it's called an ISM, with a used part off ebay and then take it to the dealer to have it programmed, will they do it? I have an Autel scanner/programmer, but I don't think the MK808BT will program these.
Odd Piggy (02-21-2024)
If I get a ISM that the seller claims was "flashed", does that mean I can just install it, or do I still need to program it?
I've tried to contact Autel a couple times and got no response. I hooked it up to another make/model and it showed some transmission options, not sure if they're the right ones though.
Flashed, I assume, would mean that it can just be installed. But that makes me wonder… The shift controller on the C-Class is on the DAS which would make me think it needs to be married to the ECU. But maybe it’s an end point device and it’s not polled. I have never had to go there, so not certain. Generally W204 and X204 are very similar.
We need someone who has a WIS handy.
I contacted Autel once a few years ago by email and they replied with the solution the next day.
support@auteldiagnostictools.com
