Aux Battery and Radio Code
Will the auxiliary battery allow the radio to retain the radio code when I disconnect the main battery?
Mine remembered presets, and I think even the clock (not sure). No code was required. (Which is good since I don't know where to find it!)
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
I've done the opposite... replaced the Aux battery with no ill affects. But the rumor is the Aux is for ECO mode support (during stop start conditions).
Personally, if I were worried about various saved settings for main battery replacement, I'd simply hook up a trickle charger to the positive feed (charge) connector, and negative to the ground point ... swap battery, and be done.
