Mercedes GLK 20 wheel
Old Apr 21, 2024 | 05:59 AM
Krzysinho's Avatar
Mercedes C32 AMG
Will rims with these parameters be suitable for the GLK? And if so, what tires would be good?
9x20 ET 32
10x20 ET 45
I left the rims from my previous car
Old Apr 21, 2024 | 04:34 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
9x20 ET 32
10x20 ET 45
Largest original rims listed are 8.5x20 ET 45 and 9.5x20 ET 57. These rims will move the tires out 12-13 mm from the original setup plus 6.25 mm because they are wider. That may cause fender interference problems, especially on the front wheels. Tire size also enters into this determination. If the GLK is lifted there may not be a problem. Check with a tire retailer to see if these wheels with your tire selection is suitable.
Old Apr 21, 2024 | 05:26 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
You should clarify what you drive. You joined a couple days ago and profile shows:
Vehicle(s) I drive: Mercedes C32 AMG
If a GLK, you should specify the year and model.
