what's the proper grease/lubricant to use for a brake pad replacement?
Old 04-28-2024, 12:12 PM
EnzoSpumoni's Avatar
2015 GLK 350 4MATIC
Fairly new to owning a 2015 GLK350, and about to replace the front and rear brake pads -- rotors look good and have plenty life in them.
What's the best brake grease to use on clips and pads? Any other areas that need grease? I want to also grease the caliper slide pins while I'm down there. Slide pins take a different grease -- silicone-based, correct?
Thanks in advance,
Enzo
Old 04-29-2024, 10:07 AM
andreigbs's Avatar
GLK 250
Last time I did front brakes, I only lubed the caliper slider pins with the supplied stuff from FCP Euro. The shims and pads get no grease, just a good spray down with brake parts cleaner, a stiff wire brush to clear any rust/corrossion.
No issues to report.
Quick Reply: what's the proper grease/lubricant to use for a brake pad replacement?
