Please help 2010 GLK 350 4matic (x204)
Old May 7, 2024 | 03:22 AM
MacMittens80's Avatar
2010 GLK 350
Ok I need help, I need somebody's expertise. So I have a 2010 GLK 350 4matic, I just recently replaced the starter. In replacing the starter I dropped the rack and pinion to get the starter out. Now I can't get it back up into position.....🤬😡😔 Also the steering wheel is loose and does not turn the tires. I'm in desperate need of help. Thanks
Old May 7, 2024 | 03:59 AM
Mmr1's Avatar
2013 glk 350
I’m no expert but why would you expect the steering wheel to turn the tires with no steering rack? And why are you trying ? Isn’t that why the rack is out of alignment and doesn’t fit. I’m confused.
Old May 7, 2024 | 09:16 AM
2010 GLK 350
The steering rack is still in, I had to drop it to remove my starter, I didn't remove it. Now I'm trying to move it back into position and it won't go back into position and the steering wheel doesn't turn the tires. Nothing was ever disconnected. I just removed the bolts holding the rack to the frame so I could pull the Starter through that hole.
There's the steering rod, the starter is sitting right above it, I dropped the rack and pinion to remove and replace the starter and now it won't go back into place so
Old May 7, 2024 | 07:45 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
OK, simple question: what is preventing it from going back in place? Is it the steering column? Is it out of place side to side? When you turn the steering wheel, not that that is a good idea, does the rack move around? Do you have the weight off the front wheels?
