EGR Maintenance Help
Old May 22, 2024 | 07:02 PM
Chris_Stone3's Avatar
GLK 250
I am looking to have my local German garage service my EGR but am having trouble on what I should replace first. Does anyone happen to know which part of the EGR needs to be replaced? It seems like the EGR valve is what I’m leaning towards. If anyone could help with the following I would be incredibly greatful:
1.) Replace egr parts or remove, clean, and reattach?
2.) Which part is a good start to service the EGR and improve overall performance?
Thank you!!
Old May 23, 2024 | 12:42 AM
MBKLUE's Avatar
Yikes:
Thank you!!
"Does anyone happen to know which part of the EGR needs to be replaced?"
It's possible. Check with your local German garage.
"Which part is a good start to service the EGR and improve overall performance?"
Definitely the part that's limiting performance, if any.
Let us know the results!! Thanks!!!
Old May 23, 2024 | 12:49 AM
GLK 250
Lol. Very helpful response. I appreciate the maturity and the help that seems overtly abundant in your response. I’m glad I’ve directly contributed to your daily good deed!! Have a good week.
Old May 23, 2024 | 10:00 AM
Mmr1's Avatar
2013 glk 350
Do you mean PVC system ? Yes MB leak when old , test vacuum or simply lift up on the oil cap when motor is running to see if it’s hard to pull up , testing vacuum is better . Mine was bad at 75000m
Old May 23, 2024 | 10:40 AM
MBKLUE's Avatar
Yikes:
You're asking a number of crystal ball questions.
If I buy a lottery ticket today will I win the lottery?
Old May 23, 2024 | 10:49 AM
andreigbs's Avatar
GLK 250
What makes you (or the German shop) think the EGR system is faulty? There would be error code(s) stored in the ECU and likely a check engine light if the system is acting up.
If indeed it is the EGR system at fault, any repairs would be covered under the AEM extended warranty and your authorized MB dealer (not the German shop) would be responsible for fixing it free of charge.
We need more information if we are to be of any help.
Old May 23, 2024 | 11:04 AM
habbyguy's Avatar
2011 GLK 350 4Matic
Andrei, that's not how the Internet works.
The correct method:
I post a vague, incomplete, and confused question.
You reply and tell me exactly which part I need to change.
If that doesn't happen, I complain that I'm still confused, but now it's YOUR fault.
Glad I could help clarify. ;-)
Old May 23, 2024 | 11:07 AM
MBKLUE's Avatar
Yikes:
The correct method:
Right off the bat I got Troll vibes. I could be wrong, or not.
Old May 23, 2024 | 11:53 AM
andreigbs's Avatar
GLK 250
Same, but I'm trying to give the guy the benefit of the doubt.
Then he goes and asks about "tire programming"...
Old May 23, 2024 | 12:07 PM
MBKLUE's Avatar
Yikes:
Somebody that has modified, aftermarket engine mapping/tuning on their GLK and refers to tire programming and indicates they are worried about the consequences of not buying rubber tires directly from Mercedes-Benz?
And who writes things like this:
"I’m seriously considering a DPF/SCR/EGR delete and am incredibly close to pulling the trigger, but I am unsure if this will resolve my issue."
I'm seriously considering... I'm INCREDIBLY close to pulling the trigger... I could go on. So yeah, jolly odd.
Old May 23, 2024 | 12:59 PM
Mmr1's Avatar
2013 glk 350
Nobody ever complimented me
before, im
a
moton , !
Old May 23, 2024 | 02:52 PM
Bill F's Avatar
2013 GLK 350 4 matic
before, im
a
moton , !
I think you are doing nicely and we are proud to have you on the forum.
signed A.I. Bot LOL
Old May 24, 2024 | 01:34 AM
Mmr1's Avatar
2013 glk 350
Ok , at least this isn’t about replacing old wiper fluid ! 🥃🥃🥃
Old May 24, 2024 | 11:25 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
I guess the first thing you have to figure out is why you're wanting to service the EGR. Is there a particular problem you're trying to address?
