2015 GLK250 front/rear brake pads and rotor torque specs
2015 GLK250 bluetec
I did a group search and seen torque specs for the GLK350 but not sure if the 2015 GLK250 bluetec has the same toque specs?
Wheel bolt:
150Nm ~ 110 ft-lbs
Front brake caliper mount external torx flange bolt:
180Nm ~ 133 ft-lbs
Rear brake caliper mount hex bolt:
120Nm ~ 88.5 ft-lbs
Front floating caliper guide pin hex flange bolt:
29Nm ~ 21 ft-lbs
Rear floating caliper guide shoulder screw:
34Nm ~ 25 ft-lbs
Are these the correct torque specs for my 2015 GLK250 bluetec?
thank you in advanced
Wheel bolt:
150Nm ~ 110 ft-lbs
180Nm ~ 133 ft-lbs
120Nm ~ 88.5 ft-lbs
29Nm ~ 21 ft-lbs
34Nm ~ 25 ft-lbs
Those numbers look close enough to me. There shouldn't be much (if any) difference between fastener torque figures across the GLK range, whether gas or diesel.
2015 GLK250 bluetec
I have a diesel. I just wasn't sure if there was a difference between the GLK 350 and 250 brake system? ir calipers etc etc
