mercedes glk 350 2013 transmission mount torque
there's 5 nuts for the transmission bracket and 4 for the transmission mount ?
Using the jack to hold up the transmission while you're R&Ring the mount can get in the way a bit, so it helps if you have a power tool to get the bolts back in rather quickly. Once they're all in, you can go around to each bolt and tighten them gut.
