Random hard steering at low speed
Look for black particles or debris when you change the fluid. That would mean the ps system needs to be flushed and hoses may need replacing.
If the previous suggestions don’t find anything, it could be the bypass valve in the pump. Test by standing on a level surface where the GLK will not roll in neutral without brakes applied. Apply the parking break. Jerk the steering wheel hard left then right a few times like performing an emergency avoidance maneuver. You should not feel any increase in effort. If you do this is a safety issue. Suspect the bypass valve, which will require a new ps pump. I’ve seen this in multiple brands foreign and domestic including Mercedes at high mileage. It could be a problem in the steering rack itself, but the pump is the first place to look.
