Tire recommendations
We went the longevity route. In June 2022, bought four 235 /45 R20 PIRELLI SCORPION VERDE AS PLUS II (740 Treadwear rating, bought at Discount Tire).
Contemplated putting on originals (Michelin xxyyzz), but after speaking with associate, opted for Pirelli. The Michelins are grippier, but short lived. And heck, the Pirellis are less expensive 👍
Due to retirement, the majority of driving is to the grocery store. On rare occasions, an 80-100 mile round trip. So for us, we don't need grippy. And our Winters last about a month, no snow, and rare to get icey roads.
What Mmr1 and calder-cay wrote.
It's kind of like asking people what's the best engine oil to use and how often should I change it. In a case like this it might be better/more useful to ask if there are any tires/brands to avoid and why.
Now with that being said, if you’re not dissatisfied with what you have, I suggest going right back to them. Why? There are many tires to choose from and IMO your chances of being unhappy with the change are greater than being happier.
That's why you're feeling a harsh ride - the rubber becomes hard and brittle over the years.
The OEM tires on our 2014 350 Base were Michelins, but I don't recall the model #'s.
Your vehicle list indicates a lot of experience, but I would still caution against getting a tire that’s too sticky or tends to oversteer on any SUV.
Guess what - that's what I was using, not realizing the gas fill cap sticker. So, in the beginning, I was putting too much air in the tires (door jam only shows air for "extra load", until I discovered the filler cap sticker ... I show both below - filler cap, then door jam
BTW, I still adhere to my opinion the age of your tires is beyond acceptable.
I’ve had them. They’re absolutely fantastic performance tires. They also do okay on snow but they don’t replace winter tires.
They’re very aggressive. If your steering feels “light” you may want to have a shop set the toe-in to the max allowable within specs. I also recommend adding 2 PSI to the fuel door pressures. I don’t think that will negatively affect the ride because their compound is quite soft.
My experience is, for an "empty" GLK 350 (just driver), 31 or 32 psi is correct. I've been measuring the tire tread wear on mine for 10+ years and the wear is even across the tire width - not wearing more on outside edges. That's for both my summer and winter tires/wheels. 20-inch and 17-inch.
