Preventative water pump change
Old Jan 24, 2025 | 06:22 PM
C300fan2's Avatar
14 GLK 250
Anyone change the water pump as a preventative measure? The mechanic just said not to do it unless there a leak or issue but I read online this water pump has internal issues of leaking coolant into the vacuum system.
Car is at 160,000 KM right now,.
Old Jan 24, 2025 | 06:32 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Are you referring to this similar thread:
https://mbworld.org/forums/glk-class...re-recall.html
Old Jan 24, 2025 | 06:46 PM
C300fan2's Avatar
14 GLK 250
That issue yes im worried about. Just cant decide whether to change it early. Mechanic said no.
Old Jan 24, 2025 | 07:12 PM
Mmr1's Avatar
2013 glk 350
My 13 80000 miles is leaking , they don’t last forever on the 2013
Old Jan 26, 2025 | 11:04 PM
fei_cdn's Avatar
2015 GLK 250
I cannot say if it is worth it to do it preventatively or not, but when I bought my 2015 GLK 250 second hand the water pump was leaking (you could smell some coolant). Luckily, there was very insignificant coolant to be found in the vacuum line.
The most important: Replace it with a new pump from Mercedes themselves. No aftermarket OEM equivalent. There is a vacuum port that is missing and is only present inside the MB pump. There is a video on YouTube from a sprinter mechanic (same engine) where he tells his tale of trying multiple pumps until he finds that the MB pump is different inside. If you don't replace with the MB pump your GLK will start throwing Check engine light about the issue. This is one case where you'll want to ensure you use the MB part specifically.
Old Jan 27, 2025 | 03:04 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
if you think about it more than not at all sir just do it please, youre gonna have to anyway at least now you don't have to care abou tit
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jan 27, 2025 | 09:29 AM
andreigbs's Avatar
GLK 250
I wasn't so much worried about the pump leaking, but at almost 10 years old and 125K miles, I opted to replace the drivebelt, tensioner, and rollers, so it made practical sense to also change the WP with the updated metal impeller type and new coolant at the same time.
