GLK350 Headlight Restoration
Old Jun 16, 2025 | 05:32 PM
droptopchevy's Avatar
2010 GLK350 4Matic
My head lights on my MY10 GLK were pretty rough, with one in particular having terrible UV damage and hazing.
I sspent a little over an hour wet sanding on the first one, starting at 400 grit which removed most of the oxidation and UV damage. After this I went to a 600, then 1000, and 2000. I probably could have skipped one of these but the final step was the 3000 grit which I began using with Meguiars Plastx. I worked that in and afterwords polished with a microfiber using the same product.
Finally I gave it a light spray with 3030 Aerospace Protectant with is a UV protecting spray.
Overall I'm pretty happy with the results. I wish I had gotten a before picture but this particular side was BAD. There's still a slight bit of haze on the edges, but I can live with it.
Old Jun 16, 2025 | 08:38 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
I did the same with my wife's 2001 E320 (sold quite a while ago) with 330,000 miles.
But I'm lazy and like to get things done *now*.
I bought a brush similar to the one shown below - prob $2.00 USD. I slid the neck into a variable speed drill and snugged it up.
I pulled out the can of polishing compound from the toolbox and smeared a bunch of compound on each headlight.
Ten minutes later (15?), I'm done. No muss, no fuss 👍
Old Jun 16, 2025 | 09:48 PM
2010 GLK350 4Matic
I think mine were a little too far gone for that, once I got done with the 400 and 600 grits you could literally feel and hear the difference in textures when all the damafe was removed.
A mini 3" DA or Orbital similar to what you have pictured would have been great though.
Old Aug 4, 2025 | 09:03 AM
Bertie_'s Avatar
GLK350, SL500 (R230), E55 (w210)
A local shop here in Toronto does excellent headlight repairs: multi-stage sandpaper and then finishes with a high quality PPF (coatings wash away). I am very happy with the result.
