Buttons near vents for rear seats (function identification help)
Old Aug 10, 2025 | 01:45 AM
Crojack_B's Avatar
2014 GLK350 4MATIC & 2011 G37 Convertible
Hi everyone!
I'm a new owner of a MB GLK350 4MATIC (2014), and have never owned a MB before. I looked at around 15 GLKs before grabbing the one I have now, as this one is in great condition at 100K miles and is fully loaded. So loaded, that I have NO idea how a couple items work lol!
What do the buttons near the rear vents do? There's a seat, with a zigzag and double zigzag line. I was assuming heated seats, but now, I'm not sure.
I also have a button near the light switch for front radar. What does that button do? When pressed the car's dash beeps - is this for the cruise control or something else?
Any insight is appreciated!
Old Aug 10, 2025 | 06:20 AM
DenisMcG's Avatar
Veteran: Canadian Forces
2015 GLK 250 Bluetec
Those are rear seat heat. Press once for low, twice for high.
Old Aug 10, 2025 | 12:40 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Welcome to the forum @Crojack_B
As a new owner , you should check for the Owner's Manual , maybe in the usual compartment
If not there, or the manual that is there, is an incorrect version for your model, go here:
https://www.mbusa.com/en/owners/manuals
Tap Owner's Manual option.
It's also highly recommended to check
  • Service warranty manuals
  • Bluetec update
  • Recall information
  • ... and so on
Keep in mind too ... there have been some "extended warranty" documents that have been sent out ... so if not original owner, you'll probably never get them.
Enjoy! 👍
Old Aug 11, 2025 | 12:00 AM
Crojack_B's Avatar
Thank you guys a ton!! I figured as much and do appreciate the clarity.
I don't have the car in my possession yet (later this week), and I wasn't able to really figure out the exact month of manufacturing - it looks like there's two manuals for 2014. Thanks for providing the link!
'Keep in mind too ... there have been some "extended warranty" documents that have been sent out ... so if not original owner, you'll probably never get them.' - you think there's any way to find the original owner and ask if they received said documentation? Not sure if it would be useful, the GLK I am receiving has 106K miles on the odometer.
Thanks again everyone!
Old Aug 11, 2025 | 10:49 AM
calder-cay's Avatar
You could ask the previous owner, if that's easy. But there are online resources to determine what's been done.
And yea, an easy way to get the year of manufacture is to open the driver's door ... on the door-jam ... you should see 1-2 stickers - the D.O.M will be there
The VIN can be found in three locations: driver side windshield, driver door jam sticker, and on a plate under the passenger seat (floorboard)
The tenth character of the VIN is coded for the year model.
You can also use a VIN Decoder, such as here:
https://vpic.nhtsa.dot.gov/decoder/
I have a PDF document of one of the Extended documents:
"Mercedes-Benz Warranty Extension Coverage - Rear Subframe"
This warranty is extended to "20 years / unlimited mileage".
... That Extension notice is attached.
File Type: pdf
Old Aug 11, 2025 | 03:18 PM
Crojack_B's Avatar
Thanks a ton for the information, will have the vehicle in hand this week so will check the vin and any progress on the extended warranty.
Super helpful information!
Old Aug 11, 2025 | 06:55 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
Those are installed aftermarket. There's only a third zone climite option for the that rear vent area and it wasn't available for the USA or Canada.
Old Aug 12, 2025 | 10:35 AM
Crojack_B's Avatar
I'm surprised, the car is overall very stock. Not sure who would have installed heated seats in the rear (there doesn't look like any changes have been made.
Thanks for the heads up!
Old Aug 12, 2025 | 10:55 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Could it have been a dealer installed option? What area did the car come from originally?
Old Aug 12, 2025 | 12:17 PM
Crojack_B's Avatar
I have no idea if it could be a dealer option to be totally transparent, according to the car fax this came from Mercedes Benz Motor Werks of Barrington Barrington, IL as the first dealer (I'm also in the Chicago suburbs).
I looked at ~15 GLK's and this particular one has much more as far as options go. Larger screen, front and rear radar, reverse camera, side mirror alerts, heated steering wheel, and others which I thought was rare considering most/all did not have this amount of technology/opt-ins.
Old Aug 12, 2025 | 12:28 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Sounds like a great catch. GLKs had excellent utility and generally good reliability. They sold at a price point competitive with similar domestic small utility trucks. Mercedes didn’t want to live there, so “poof” it turned into the GLC the next year which is a completely different vehicle.
Just read the threads about checking and maintaining the output shaft between the transfer case and the front differential.
Old Aug 12, 2025 | 12:51 PM
Crojack_B's Avatar
Thanks Piggy,
Definitely a great catch, also very happy the search is finally over lol.
I'll take a look at those threads and review, doing most work myself (aside from engine/trans fingers crossed). Everything looks pretty solid under the hood and the undercarriage but always good to have resources for when the inevitable happens.
Still trying to find out exactly what the front radar is for, since there's no front cam and it doesn't look like I have the radar-adaptive cruise control (no swivel on the stalk)
Old Aug 12, 2025 | 04:49 PM
John CC's Avatar
Go to www.lastvin.com and look up the build sheet for your VIN.
Old Aug 12, 2025 | 11:44 PM
Odd Piggy's Avatar
You’re not getting any replies on that, so it must be rare. My ‘15 GLK was base model with only a few options, not even a sunroof. Maybe it’s got something to do with forward collision warning or parking. Looking up your data card on lastvin.com, as mentioned earlier, might help with the mystery. MBs can get a number of “hidden” features that other brands would advertise.
Old Aug 13, 2025 | 07:22 AM
calder-cay's Avatar
-- radar guess --
Possibly this radar sensor
https://mbparts.mbusa.com/oem-parts/...sensor-9055701
Radar Sensor - Mercedes-Benz (000-905-57-01)
Description:Adaptive cruise control system. Blind Spot Assist. City assist system (cas). Short range radar. Distronic. Left and right.
Old Aug 14, 2025 | 03:46 PM
Crojack_B's Avatar
After playing around with it a little bit, it's not the adaptive cruise control (Distronic) - no slider/switch to change distance on the cruise control. It does however beep when there's an object/person in front of the vehicle and it does have the lane assist as well as blind spot assist.
Falling in love with the vehicle more and more as I learn more about it!!
Can't believe all the options it has (including the 20" wheels/heated rear seats).
One thing I'm a little puzzled on - does the 2014 not have a compass in the mirror? I really liked that about the 2010-2013 models I looked at previously lol.
I decoded the VIN as recommended, and I dont see rear heated seats - I should just test that button and see if they heat up lol. Unless it's part of the FX package (Special Version?)
Whoever loaded this up on purchase, I salute you - most people don't option this car as it's a 'base' model SUV as far as I understand.
Old Aug 14, 2025 | 06:36 PM
John CC's Avatar
You can display compass headings in the speedometer where the odometer normally shows (along with a whole bunch of other things, like a trip computer)...
Old Aug 15, 2025 | 12:15 AM
JohnnyC's Avatar
The compass is also displayed in top corner on the multimedia screen. You can also unlock the offroad option through an adequate handheld scanner. I did a ceiling trim swap to a two tone so I unbeknownst bought a mirror with the red compass.
Old Aug 15, 2025 | 03:05 AM
Odd Piggy's Avatar
You just inadvertently told us exactly where LaLaLand is, which looks like Ontario, CA. Maybe blur those coordinates?
Old Aug 15, 2025 | 09:44 AM
John CC's Avatar
Mine is a bare bones car as far as options. Of the ones you circled in red, the only ones I have are the air bags and the rain sensor (for the wipers, I presume). Oh, and "FX", so don't feel special!
Old Aug 15, 2025 | 11:35 AM
Crojack_B's Avatar
So it's pretty stupid, but growing up (I'm 34) my fam never really had luxury cars, I was always jealous of the red compass on the rear view mirror when I would see them. I like the capability without having to use the cluster or display to show the direction - could I buy a used mirror from a 2013 and it would fit and work with the compass? (assuming it also has auto dimming)
Old Aug 15, 2025 | 11:37 AM
Crojack_B's Avatar
Lmao whelp I guess I'm just another average joe
Old Aug 15, 2025 | 02:51 PM
calder-cay's Avatar
Agreed!
This thread is DRIFTING in a bad way.
Hint: start a new thread for subject matter that is COMPLETELY different than "heater buttons".
Old Aug 15, 2025 | 02:58 PM
Crojack_B's Avatar
Originally Posted by calder-cay
Agreed!
Apologies as I'm new here to MBWorld as well as Mercedes-Benz in general, I'll review for the rules of the forum. I wasn't aware that asking additional questions (unrelated to original inquiry) was against terms. Original inquiry is resolved.
Thanks again for the assistance those who chimed in with knowledge.
Old Aug 15, 2025 | 03:28 PM
calder-cay's Avatar
Appreciate your understanding.
Jumping subject matter as a "shouldn't do", has zero to do with this forum ... or any other.
Every forum ... cars, computers, mowers, refrigerators, lawn car, ad nauseum ... it's all the same ... (my experience in the last 30+ years) ... start a new subject thread if different 👍
