2015 MB GLK350 Evap code p00455 the aux battery malfunction
Old Oct 9, 2025 | 09:18 PM
Shrumsjs's Avatar
2015 GLK350 108k miles2008 clk350 Cab 180k miles. 1998 E300TD 237k miles
I recently got a CEL P00455 EVAP massive failure. Swapped gas cap didn’t help. Then after a week and 200 mile got “Aux battery malfunction” message that killed The CEL. So I am replacing Aux battery. Here is my question. Current battery is not OEM but has lasted over six year. Mm Mighty Max MODEL YTX14-BS12 VOLT 12 AMP HR.availale for $40 vs $150 OEM. Any reason I should not use this battery mind know you get what you pay for. TIA to reply’s.
Old Oct 9, 2025 | 09:46 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
Just use the cheaper one as long as it has the same specs. I bought my used GLK350 in 2022 and the previous owner put an autozone AGM battery. Hasn't skipped a beat yet.
Old Oct 9, 2025 | 11:45 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Aftermarket batteries are fine. Mine was replaced with a 12V 14AH Duracell alarm backup battery from Batteries+.
Old Oct 10, 2025 | 06:57 AM
Mmr1's Avatar
2013 glk 350
It’s easy to overpay for an AGM auxiliary battery. Not to many companies make them so how much difference can there be ? I found an AGM on Amazon for 60$ about 4 years ago that’s been fine. Just get similar rating and terminals . I had to bend mine to get it to work.
