GLS Class (X166) Produced from 2016 to 2019
Center console is burning HOT!!!
Old Mar 7, 2017 | 08:10 AM
Joey Base Ball's Avatar
2017 GLS450
We just purchased a new GLS450 about a month ago and last night I grabbed my sunglasses out of the bottom storage area (the one under the heating controls). My sun glasses were burning hot and when I reached my hand inside to feel it I couldn't touch it. Going to call the dealer today but has anyone else had this problem? The car was running for about 45 minutes before we noticed this. Thanks..
Old Mar 7, 2017 | 08:23 AM
amgnut's Avatar
04 SL55, 16 GTs, 17 GLS 63
I have noticed this too-extremely hot. I left my key in there once and after about an hour of driving the car freaked out saying no key detected.
Old Mar 8, 2017 | 02:36 AM
350MH83's Avatar
2017 GLS 350d
I checked on mine during use and could not feel anything. The area wasnt hotter than any other piece of the center console... I have a GLS350d without heated cup holder. Do you guys have the heated/cooled cup holders?
Old Mar 8, 2017 | 07:47 AM
2017 GLS450
The heated cup holder was not on at the time.i did check it 2 more times after that and it was not hot.. I'll keep my eye on it now everyday to see if it happens again.
Old Mar 10, 2017 | 06:06 PM
redcarrera's Avatar
'25 Range Rover P530, '21 M5Comp, '17 GLS450,'17 Range Rover, '08 Carrera 4S
New GLS450 here. I've driven about 2,000 miles in the Colorado mountains in the last month and haven't noticed any heat in the dash storage bin.
Old Dec 12, 2019 | 08:53 PM
Liam Tanelli's Avatar
Gls450
2020 GLS459
I have the same problem. I also have the heated cupholders.
What was the issue, dealer they never heard of the issue before.
Did anyone get this fixed? I would like to know what it is to help expedite the process.
Old Dec 12, 2019 | 09:18 PM
chassis's Avatar
2017 GLE350 4MATIC
The posts on this thread are made during cooler months in North America. None of the posts were made during warm months.
I noticed my console was rather warm, and found that by closing the rear seat air registers it solved the problem. When warm air is called for, as it is during cooler weather, the console is warmed by warm air flowing through a duct in the console, supplying the rear seat registers.
The suggestion is to be sure the rear seat registers are affirmatively closed.
This topic has come up before on this site, try the Search button or Google.
Old Dec 22, 2019 | 08:32 PM
GS2020's Avatar
GLS580 and 2020 Corvette
Hot console
we have GLS580 and same issue after only 100 miles and in FL. Dealer has it back trying to find solution. If anyone has found solution, please advise here
Old Dec 22, 2019 | 08:39 PM
chassis's Avatar
2017 GLE350 4MATIC
GS2020, did you affirmatively check the console vents for the rear passenger are closed, and conduct a test?
Old Dec 22, 2019 | 08:43 PM
GS2020's Avatar
Hot console
no we did not check rear vents - did not know we should. We live in FL and air conditioning was running, not heat.
Old Dec 22, 2019 | 08:56 PM
GS2020's Avatar
Hot console
dealer here in South Florida has not seen this issue - we run air not heater
Old Dec 22, 2019 | 10:07 PM
chassis's Avatar
2017 GLE350 4MATIC
Do a test where you fully and firmly close the console registers at the rear of the console. Then operate the climate control for an extended period. I have been in Florida plenty of times when the heat was needed in the morning. Not nearly as often as in the north!
Old Dec 22, 2019 | 10:11 PM
GS2020's Avatar
Heat
again, this was when outside air was 78 and air was running to cool inside - it was not cold out!
Old Dec 23, 2019 | 12:27 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Happens on mine when I operate the cup holder coolers. In Florida. It was so bad on one trip that I had to put a pillow between the console and my legs. Must have been 150 degrees or more.
Old Dec 23, 2019 | 09:55 PM
GS2020's Avatar
Hot Console
chassis- you were right! Issue was that vehicle came from factory with rear vents closed and heat setting on HI, so even though air was working in front row, heat was being sent to second row but vents were closed so heat accumulated in console. Sales people and I did not think to look for that stupid set up from factory 😪
Old Dec 23, 2019 | 10:10 PM
chassis's Avatar
2017 GLE350 4MATIC
Glad you got it sorted.
Old Feb 5, 2021 | 03:40 PM
WiscoMB's Avatar
2017 GLE350 4MATIC
Hi all,
I just took my '17 GLE to the dealer in Wisconsin. Very cold here in winter and we have been having this heat issue (161 Degrees F in coin pocket under the dash), and i brought in the car with the issue present.
MB Dealer said they have never seen this before, so they took apart the whole center console/dash to investigate.
They found nothing wrong with ducting/assembly, but they also replicated the problem on 2 different cars.
They concluded this was normal when running heater for long periods, especially if vents are closed.
(FWIW they did not charge anything for this service)
Old Nov 5, 2023 | 08:54 PM
Nazarim's Avatar
GLE2024
Inside console arm set is getting hot when heat is on
  1. In my GLE2024 Center console is burning hot after 5 min runs the heat. I opened the front and rear but inside the console is still sooo hot
