GLS Class (X166) Produced from 2016 to 2019
Correct tire pressure for 21 inch wheels?
Old Jun 15, 2017 | 12:52 AM
jbak31's Avatar
gl550
I recently noticed my 550 has 32 psi written as normal tire pressure on the inside of the gas tank lid. My tires were always pumped to 38-40 psi, because that's how it originally came. Which is correct? Should I deflate to 32 psi?
Old Jun 17, 2017 | 11:48 PM
bylife's Avatar
GLS350d s
I am using 39 for front and rear at moment.
Old Jun 28, 2017 | 03:02 AM
dfride's Avatar
2017 GLS 550 - 2023 S580
was told to use the info on the gas tank door. normal load says 35 front and 36 rear. this is on my 2017 GLS550
Old Jun 28, 2017 | 02:09 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
I am using 39 PSI in my 450 GLS, mainly for the extra suspension "spring" of the higher inflation pressures (i.e., firmer).
I am also getting 20 MPG on moderate trips in the city....
