Anyone hardwire a dash cam?
Has anyone hardwired a dash cam in the GLS yet? Did you use the fusebox on the front passenger side of the vehicle or the fusebox under the rear seats? Which fuses did you attach it to?
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
I tried to hardwire my dashcam into the fuse box in the passenger side but every fuse i tried I couldn't get power to draw to my camera.
It was frustrating; because I was able to do it flawlessly in my vw jetta gli...
What I ended up doing was just getting a roav dashcam which had the battery built in and using the DC outlet in the passenger footwear and routing the cable up and through the dashboard and passenger headlining.
Cheers
Cheers
Cheers
Cheers
I hardwired mine under the rear right passenger seat fuse box. It was quite easy and took only a few minutes. I installed mine in my ml350, but I imagine that the process would be nearly identical in the GLS.
Hard Wire connection tapped to Fuse 151. A BlackVue PowerMagic Pro should be able to be hardwired similarly.
BlackVue b-124 placed above the access panel for the rear fusebox.
That's what I thought until the check engine light came on just from tapping the fuse.
The GLS is 5 years newer than the ML and they must have changed something because I had no issues installing a backup camera in my 2014ML.
