GLS63 Needs Carbon Ceramic
1. the size of the gas tank.... range is just too small
2. Brake Rotor hats are all rusty look terrible
3. Brake dust
Does anyone know if E63 cc rotors / SS hats are compatible?
I want to keep the original big AMG calipers.
My issue is the rotor hats and dust.
Carbon Ceramic would solve both.
My LP 640 has carbon ceramic and seems to be 0 dust. Not to mention how cool they look.
I have found with ceramic you can step on the brakes much harder without the "bite" that passengers aren't too fond of. Just easier to modulate for a smoother feel.
In any case the brakes only stop the wheels, it's the tires that stop the car.
or this too
https://tro-nik.com/carbon-ceramic-k...-amg-gl63-amg/
or this too
https://tro-nik.com/carbon-ceramic-k...-amg-gl63-amg/Sent email ot tro-nik, in the mean time I just ordered EBC 31939C pads for front and yellow stuff for the rear
Final results....
2017 GLS63 AMG
EBC Brakes DP31939C ceramic pads
only $91 on Amazon, great dealThe rears got complicated. EBC only made the "yellowstuff" high dust high bite race/drift pads.....amazon didn't explain this but the ebc instructions clearly did.....DO NOT install if you don't want dust.....
ok returned them....
Akebono had no size, as far as I could tell.
Finally found Brembo made ceramic pads (only for the rear!?).
For Mercedes X166 GLE63 AMG S ML63 AMG Brake Pad Set Rear Ceramic Brembo P50101N
only $42. delivered on ebay.
we installed the front, took about 40 minutes on the passenger side, and 20 mins on the driver side after we learned a little.
we were careful and did not have to change the original WEAR Sensor.
Waiting for the rear pads to arrive.
Driving impression on the front pads is A+ EXCELLENT. Better than stock! ! ! ! !
fyi.....MB Anahim quoted me $1200 for f/r MB pad replacement.
What you stated is reminiscent of the original carbon brakes that came out in the early 2000s, which literally were a race-only application, and didn't work well (ie stop well) until at operating temp. That's a far cry from the carbon ceramic brakes currently available on vehicles nowadays.
For the record, I have a C63S Edition 1 Coupe with the factory carbon ceramic brakes, and they're AMAZING. I currently have 55K miles on them. Zero brake fade. Zero brake dust. Zero problems. Zero issues. And they work in all temps and under all conditions. Meanwhile, I've been through SEVERAL sets of rear pads AND rotors, which are traditional (C63 only comes with front carbon ceramics).
As for brake failures, again, where are you getting your info from? I personally have never heard of an AMG carbon ceramic rotor failing or even requiring replacement since they introduced them on their vehicles several years ago - unless you track your vehicle. But with street use, it's pretty much common knowledge that you'll get well over 100K miles out of the rotors, and the general understanding is they're "lifetime" rotors that should last the expect duration/lifetime of the vehicle's meaningful use, provided it's normal daily street use. In that time period, you will be EATING through pads and rotors on a heavy car like a GLS or an S class...
From another thread (S-Class forum):
https://mbworld.org/forums/coupe-roa...-warranty.html
https://www.autotrader.com/car-news/...-plague-267318
