Loose Buttons in Center Console
Anyone else have this happen?
EPC shows the part as a whole unit with no separate buttons.
Good luck.
What I thought was unglued, appears to be a broken tab tower.
It mounts on two tabs, and it looks like one of the tabs has part of the tower broken off. I’m inclined to see if I can either find a replacement, or use some type of glue and UV light, to rebuild the little tabs broken off.
We’ll see. (or I let gravity hold it in place and be more careful when vacuuming).
This picture should help.
Broken tower or tab on the top. What looks like a normal tab on the bottom.
Same switch rotated, good tab on the top, and broken tab on the bottom.
