Wheel noise help
Were the pads worn abnormally compared to the other side?
noise is still there after carefully inspecting caliper, regreasing the pins & pads edges, lightly sanding the pads, disc quiet spray at the back of the pads, caliper pushes back smoothly with C-clamp no sign of sticking, even bleed the brake line (all 4 done about a month ago). I've done brake jobs on my other vehicles but never an issue, the other front wheels is quiet as ever, no changes to the noise not quieter or louder making me think that it could be wheel bearing since the car parks at a slight incline overnight after backing into the drive way at night is it possible? rotor looks good but will not rule out the possibility. It's so hard to trouble shoot since everything is super quiet all day after the first 2 initial stops. I personally would leave it as is but my wife leaves early for work and it's embarrassing to have the car sounding like that. Any suggestions?
2) clean the disk aggressively with CRC BraKleen, Buff the working surface with 100 grit silicon sand paper.
3) Make sure the pads don't bind in the caliper frame.
4) Stop worrying about what other people think...
[Edit] My question before about pad wear was intended to compare the left side with the right side, not the inner and outer pads.
If all else fails, you can try swapping the pads left and right, to help narrow down the problem.
