GLS Class (X166) Produced from 2016 to 2019
Fog Light install?
Old Feb 22, 2022 | 12:17 PM
HVYDRP CL's Avatar
2014 GL63, 2016 S550 4Matic, 2015 HD Roadglide
Fog Light install?
Hello all, I want to install fog lights on my 15 GL550. Any body else do e this? if so where did you tape for power, what switch did you use and what type of lights?
Old Feb 24, 2022 | 02:10 PM
Groundhog101's Avatar
GLS550
I am looking and searching for the same on a 2019 GLS 550
Old Feb 25, 2022 | 07:15 AM
clarkpittman's Avatar
GLS550, GLE450 Coupe
On the 2019 "S" class GL the headlights automatically correct for the fog light requirement situation if you have the "LED Intelligent Light System" headlights and you have turned the fog light switch on. This system also incorporates a brake light fog lamp on the driver's side brake light assembly.
Old Feb 25, 2022 | 10:51 AM
GLS550
Yeah I do have that …was looking for the bottom LED bar setup aftermarket that goes at the bottom two corners
Old Feb 25, 2022 | 10:54 AM
In my opinion that would make your "S" class look like an "E" class or an older "GL". I think the GLS looks cleaner without the extraneous lights on the bottom corners.
Old Feb 25, 2022 | 10:58 AM
GLS550
Good point …..so the stock DRL I understand it has a break light turns ON, does it have any Impact or change in the front other than the Stock DRL being ON?
Old Feb 25, 2022 | 11:03 AM
My understanding is that it does affect the functioning of the headlights as well as enabling the brake fog light function. Watch the attached vid...
