GLS Class (X166) Produced from 2016 to 2019
2016 GL450 lower oil pan gasket
Old Oct 27, 2022 | 09:35 AM
Petro55's Avatar
2016 GL 450
Hello,
I just swapped out my motor mounts and noticed my lower oil pan is leaking. I cant find a part number for a gasket so I assume it is just a liquid gasket? Also does anyone know what the torque spec is on the lower oil pan bolts?
Thank you.
Old Oct 27, 2022 | 02:09 PM
FWP!'s Avatar
2017 GLS 550
I'd make sure the oil is coming from that gasket because Mercedes is known for having leaky valve cover gaskets. I thought the rear main seal went on our GLS 550 because of all of the oil we saw around the lower oil pan, but it was traced up the engine to the valve covers, the gaskets were replaced and the leak is gone. I know, different engines, but the same valve cover gasket material is used.
