GLS Class (X166) Produced from 2016 to 2019
Brake pedal noise
Old Apr 19, 2023 | 04:03 PM
mike10872's Avatar
2018 Mercedes Benz GLS 450
Brake pedal noise
2018 GLS 450 96k
Performed a routine brake flush now the pedal makes a clunk noise after releasing it. slowly releasing the pedal the noise is not there. See video. Any thoughts?
File Type: mov
Old Apr 19, 2023 | 05:18 PM
chassis's Avatar
2017 GLE350 4MATIC
The only clunk I hear is the brake pedal contacting the white switch in the return stroke on the left in the video. Normal.
Old Apr 19, 2023 | 05:28 PM
mike10872's Avatar
the switch is all plastic, this is more of a metal clunk coming from firewall area.
Old Apr 19, 2023 | 10:07 PM
chassis's Avatar
2017 GLE350 4MATIC
I am not hearing abnormal noises in the video.
Old Jun 23, 2023 | 03:14 PM
mike10872's Avatar
update: after bleeding the brakes for the 3rd. time say lots of air bubbles. Now the pedal is back to normal. Thanks All!
Old Apr 2, 2025 | 01:24 PM
BGT's Avatar
BGT
GLS 2019
2019 GLS here. I have the same problem. The dealer did an extensive "repair" a year or so ago. Replaced brake cylinder, booster, flushed the line etc. The problem came back after 10k miles. Took it back. and now they are essentially repeating the same repair (replacing cylinder, booster etc.) and expecting different results. They are saying that may be the previous parts could be defective. Only time will tell. This is the 4th time I am at the dealer for this problem. The first time they swapped all the parts, the next time they "could not find an issue". The third time, flushed the lines. Fourth time, they are swapping parts all over again. Getting tired of MB at this point.
Old Apr 2, 2025 | 03:45 PM
W205C43PFL's Avatar
Sorry to hear that, fair to say you tried more than 1 MB dealership?
