WRONG THREAD DELETE Soft Close Driver Door Fuse Location
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
All:
Anyone know where the fuse is located? My driver soft close isn't working. I know it could be the actuator but I'd rather start small.
Also open to other suggestions. All other doors work fine.
I thought it was the actuator but it wasn't. Couldn't fine fuse at all so I just removed the door panel with care you don't need to disconnect the lock wire. The big door module will need to be disconnected from all power cables and turn the car in on position of ignition then connect all again and I'm hoping it will work. The easier way is to find the fuse but here we are. Door module fuse, couldn't find it so far.
