Vibration and Noise
Following are the symptoms:
- When driving slowly (20-30 mph) on the local road (very smooth asphalt road), I heard a noise that sounded like interior or seat friction. I suspect it is caused by some kind of lightweight vibration.
- When driving on the highway (very smooth asphalt road), at around 68 +/- 5 mph, I felt strong vibration from both the steering wheel and driver seat.
- When driving on the highway, the passenger headrest is vibrating. When the speed is around 80 mph, the vibration sometimes is strong enough to make noise.
- When driving on the highway, at around 60 mph, I can hear a rhythmic, constant droning/thumping noise from the chassis. This noise is quite different from plain road noise or wind noise.
May I ask what "bad tire" means? Different spec (e.g. weight, wear) from other 3 tires, or imbalance, misalignment?
I double checked the CPO service history from the dealership when I bought the car (Jan 2021). There are two items related to tires:
Operation Code Operation Description
40MBZ-MTBAL3 *MT & BAL 3 TIRES
40MBZZTIRE1 TIRE CONCERN
I have no idea about what they exactly means, but seems the dealer indeed adjusted 3 tires (maybe another tire is bad?) I really appreciate any insights.
CPO service on Dec 2020.
Job Operation Code Operation Description
5 40MBZ-MTBAL3 *MT & BAL 3 TIRES
9 40MBZZTIRE1 TIRE CONCERN
1st repair on July 2022:
- 4 wheel alignment, adjust front and rear toes
- balance wheels. 3 out of 4 wheels are with excessive road force
- rotate wheels from front to rear
2st repair on July 2022:
- 4 wheel alignment, adjust front toes to factory spec
- calibrate ride height to factory spec
- all tires balancing is ok
- rear wheels bent with excessive road force, wheels sent out for repair
Yeah, the tire is Continental Cross-Contact. Your suggestion inspired me to check the manufacture date of each tire, as the dealer only replaced 3 out of 4 tires when CPO service.
The car was made in Nov 2018, and the manufacture date of 4 tires are:
- 44th week 2018
- 39th week 2020
- 40th week 2020
- 2nd week 2021
I just checked the tire tread, the 2018's tire tread has not reached the 2/32 inchs, but it's 2mm less than 2020's tire. Notable the older tire runs 38k miles than other three. I suspect tread gap might cause imbalance and vibration, does that make sense? Thanks!
- 44th week 2018
- 39th week 2020
- 40th week 2020
- 2nd week 2021
The dealer happend to have another GLS550. They replaced my tires with the ones from another GLS550, and did road test. After rounds of replacement with different combinations (e.g. front left + right rear), they identified my front two tires were problematic.
Then the dealer ordered two new continental tires from their tire distributor. However, the issue was still there. Seems the brand new continental tires were also prolbematic. The dealer send all tires (including two new ones and my all four ties) back to the distributor, and the distributor did full quality test on these tires.
Finally, the distributor gave up the forementioned 2 new ties and relaced 3 of 4 tires. The issue was gone.
So, I had the four-wheel alignment done by an independent shop with the camber all around set as close to zero as they could (rear camber IS adjustable on the 550), and I had all four tires replaced with Michelin Pilot Sport All Season 4's. No more cyclical droning and less tire cupping.
I aksed the dealer if they replace with Michelin, according to FWP!'s suggestion above. However, the dealer can only replace with Continentals, as it's MB's OEM supplier.
Cross-fingure for the new Continentals!
