GLS Class (X166) Produced from 2016 to 2019
GLS450- Parking Brake wont disengage
Old Dec 18, 2023 | 05:54 PM
ph2426's Avatar
2017 GLS 450
We have a 2017 GLS 450 and recently the parking brake has not been disengaging when putting in gear. For the past week or so every now and again we have to pull the parking brake to release it but today that release didn't work at all and the brakes were stuck on. We turned the car off and then came back and got in and it worked fine again. I am not sure what this is and wondered if anyone knew as I didnt see anything related to this in the forums. Before I go tot the dealer, would anyone have a clue what this could be? thank you.
Old Dec 18, 2023 | 09:55 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Yes, very common issue. Order one and replace in your driveway. If you can change brake pads, you can change the e brake actuator.
Old Dec 19, 2023 | 07:36 AM
ph2426's Avatar
2017 GLS 450
thank you for the response. I googled them and see what it looks like and I’m happy to change it. Are there one each side and is there a way to decipher which needs to be changed? Thank you
Old Dec 19, 2023 | 07:40 AM
ph2426's Avatar
2017 GLS 450
Also, can these be lubricated? I noticed it first started after washing the car and not driving it after
Old Dec 19, 2023 | 09:13 AM
BlownV8's Avatar
If I recall correctly, it is a sealed unit. These are not expensive and they all go bad. I would even say to do as preventative maintenance every 100k miles or less if you live in a salty environment.
Old Dec 19, 2023 | 10:24 AM
ph2426's Avatar
2017 GLS 450
ok thank you very much! I have ordered and will change both to be safe. thank you!
Old Feb 7, 2026 | 10:16 PM
Vince Carpenter's Avatar
2018 Mercedes GLS450
I have a 2018 GLS 450 last month (January 2026) when the morning temperature was below 30 degrees, the parking brake would not disengage. Once the car was fully warmed up (for 15+ minutes) the temperature rose and the parking brake would disengage. Even if it is a cold day, it would work fine once you got past the initial sticking point. My research, pointed to perhaps the battery needs to be replaced so that will be my next service visit (and Spring is just around the corner) SMH
