GLS Class (X166) Produced from 2016 to 2019
Dash cam wiring?
Old Mar 3, 2024 | 07:08 PM
FWP!'s Avatar
2017 GLS 550
Dash cam wiring?
I'm trying to find an ignition-on source in the fuse panel that is inside our GLS down in the front lower right hand corner (passenger side here in the US). I am finding plenty of 12v constant sources, but not finding any that only get 12v when the ignition is on. The camera I have needs both to operate while the car is running as well as when it's parked. Has anyone installed on of these and got it wired in successfully?
Old Mar 4, 2024 | 09:32 AM
Conchasjim's Avatar
2016 GL350
Switched wire
I was able to find a switched wire in the rear view mirror for my radar detector. I used a test light and simply tried different connections until I found what I needed. Several have a time delay, so keep that in mind after switching off the ignition.
