Random Issues - New purchase
1) Side Bolsters & Massage Function… Massage seems to be not working, or working but very very weak. I could swear I felt it one day very faintly, but most times, I don’t feel anything. I also tried to adjust the side bolsters, and the first time, they adjusted, and when I got in the car next time, the were at 0 again, so I went in to adjust and as soon as I select any number, it just goes right back to 0 on the display. It seems to be intermittent, but any time I adjust, if it does hold, within a few minutes, I can feel them going back to 0.
2) Very faint clunk in the front end that I can feel in the steering wheel, mainly at low speeds over bumps, or at higher speeds over consecutive smaller bumps. I looked underneath as best I could with the car raised all the way up on a slight incline, and all swaybar ends and tie rod ends seem to be solid, but the car was still on the ground, have not had a chance to get it on a lift yet.
Anyways, still glad to be back in a MB, and it definitely compliments my other toy well… Thanks for the help in advance!
The first thing I would do after an oil change and air filter change is get it to a reputable independent euro repair shop for a four-wheel alignment. I would have them set the rear camber as close to zero as possible and have them advise about ball joints at that time.
Welcome back!
Welcome back!
Since you’re close to me, any recommendations on a shop? Was thinking Modern Mercedes?
I did use Denton European (as I'm outside of Denton in Aubrey) to do the 4-wheel alignment. I did that because I couldn't get MB of Plano to deviate from factory camber specs on the back wheels. I wanted them as near to vertical as possible (camber is adjustable on the 550) so I used an independent shop to get it done the way I wanted. It is not eating back tires now.
You might consider Fifth Gear Automotive. I've had them do work on other cars in the past and they are very good; more expensive than most but very good as well. All of that said, your Modern Mercedes shop sounds like a good solution for you.
Thanks! I have no issue coming up to Denton, have friends in Aubrey/Prosper anyways so I'm up there a few times a month at least. I will look them up and ask about the alignment specifically. I noticed camber is heavy when down in sport mode, which I like to drive in more often than not, so would def like that adjusted asap.
