How much coolant?
If you’re only swapping the thermostat and topping up after, just grab 2 gallons of coolant (that’s about 7.5L) and you’ll be more than covered. Just make sure to get the right stuff—MB spec 325.6 (G48) or their own blue coolant. Worst case, you end up with some extra for topping off later.
To get to the T-state I'll have to remove the intercooler, I'll have to drain that some how (is there a good way to do that on these? or just pop the lowest coolant hose on it and try to catch what I can with a pan underneath?)
Lastly, what's the best method to refill / burp that intercooler with out a vacuum system?
