GLS Class (X167) Produced 2020 to present
Tire pressure check
Old Mar 22, 2021 | 03:58 PM
VG2010's Avatar
GLS 550
Tire pressure check
According to the manuals I should be able to see tire pressure and tire temperature when I am going to service window and then pressing on tire.
Unfortunately tire pressure does not display, instead I can see just Tire pressure system active. How can I check tire pressure?
Thank you.
Old Mar 22, 2021 | 04:49 PM
darlop's Avatar
a
Its not available in Canada.
Old Mar 29, 2021 | 09:55 AM
neetorama's Avatar
GLS580
Could be wrong, but I believe the car needs to run for a few minutes before tire pressure is displayed. Not sure if that means actually driving or just on and stationary.
Old Mar 29, 2021 | 01:04 PM
Electric Lizard's Avatar
'14 E550, '14 911 C4S Cab, '12 ML350
I can on the Mercedes Me app.
Old Mar 30, 2021 | 05:54 AM
wolds's Avatar
2017 Chevy SS, 2018 GLA250, 2020 GLS580
I only use the app to check it, unless a warning pops up. Needing to drive around is definitely a factor, the values definitely don't update continuously (or even close).
Old Apr 5, 2021 | 09:24 AM
Paxfobiscum's Avatar
Chevrolet Chevette, Ford Pinto, Pontiac Aztek, Trabant, Yugo GV (and all the worst cars ever built)
This.
Once you drive around a bit, the sensors update the system. It also updates the data on the Mercedes Me app.
The numbers are fairly accurate. I have a digital gauge and it confirms what the sensors state.
