GLS Class (X167) Produced 2020 to present
2023 GLS ‘My Favorites’ not saving
Old Feb 13, 2023 | 07:47 AM
MarknApril's Avatar
2023 GLS 63 AMG
I have set this up multiple times with about 10 XM channels as favorites. It works when I do it and can scroll thru. However, when I turn off the car and come back to it, they are gone.
i have not changed profiles. It is driving me crazy
Old Mar 11, 2023 | 07:46 AM
MarknApril's Avatar
2023 GLS 63 AMG
I’ll update my previous thread.
Every time I start the car, the radio channels revert back to factory on XM. Every time I have to select to my favorites list so I can scroll through them on the wheel.
for instance, when working, I scroll through 8 XM channels that I have saved as favorites. When I restart the car and go to scroll through them every XM channel shows
Thanks for any help
Old Mar 11, 2023 | 12:39 PM
TNS550's Avatar
2015 MB S550 & 2020 MB GLS 450
I have a similar, or maybe the same frustration you have.....I have several SiriusXM stations set as Presets that I want to control from the left hand touch control on the steering wheel. Sometimes when I start the car the control remains on SiriusXM Presets, but sometimes it reverts to SiriusXM (all the stations). When it does that, I have to push the touch control and scroll down to the SiriusXM Presets and push the control again to be able to control the Presets. There seems to be no pattern as to which it will be when I start the vehicle. I have not been able to determine how to have the control stay on the SiriusXM Presets.
Old Mar 11, 2023 | 12:42 PM
MarknApril's Avatar
2023 GLS 63 AMG
Exactly my problem! I wish the would do a software patch to fix this.
Old Mar 11, 2023 | 01:48 PM
Eaton's Avatar
Top Answer: 1
This is a known issue and if the dealer updates the MBUX, it should fix it.
Old Mar 11, 2023 | 02:14 PM
TNS550's Avatar
I need to go back to the manual. I thought "Favorites" covered a variety of settings and was not the same as SiriusXM Presets?
Old Mar 13, 2023 | 10:09 PM
MarknApril's Avatar
2023 GLS 63 AMG
Thanks for the reply. Can I update manually or do I have to take it in?
Old Mar 15, 2023 | 02:49 PM
MarknApril's Avatar
2023 GLS 63 AMG
Eaton - I noticed this is still "in development".
Is that what you see also? Wondering when this will go live?
Thanks!
Mark
Old Mar 15, 2023 | 02:51 PM
Eaton's Avatar
Top Answer: 1
You have to take it in.
Thanks!
Mark
It's possible the fix is out by now. Sometimes they forget to post an update to the document, or take a while to do so.
Old Mar 15, 2023 | 03:00 PM
MarknApril's Avatar
2023 GLS 63 AMG
Thanks!
QUOTE=Eaton;8739746]You have to take it in.
It's possible the fix is out by now. Sometimes they forget to post an update to the document, or take a while to do so.[/QUOTE]
Old Mar 21, 2023 | 04:23 PM
MarknApril's Avatar
2023 GLS 63 AMG
got it fixed this morning. This MBUX software upgrade is available (the only one listed above in this thread marked as 'in development'). It is not available online - the dealer has to do it. Was a 2-hour download on a dedicated LAN line so it must be a massive file
I have a 2023 GLS 63
