2022 GLS 450 - Man I Regret this Purchase
I think that's pretty good for a performance tire.
I think the negative camber in the rear is just right.
And even though one of the vendors here keeps trying to sell aftermarket alignment parts, he ought to be focused on domestic and Japanese cars that seem to have more negative rear camber.
But I don't think they need aftermarket parts, either.
Specially designed to install so no special tools required or time consuming need for control arm removal. Then precise single wrench adjustable. ULTIMATE - direct on alignment rack UNDER LOAD.
When it comes to Mercedes Benz models similar kits.
Suit all Sedans, Coupes, Wagons, AMG and SUV’s. Including current W167 GLE and GLS !
GLS models - prices starting at $89,000 - was not long before we received requests for front and rear adjustment kits. Owners in disbelief that ongoing adjustment was not included - that onus now on themselves to fund costly, premature tire replacement !
Background re deletion of adjustment - it is all to do with ever increasing speed of new car assembly lines !
Now a “Full Front & Rear ‘4’ Wheel Alignment” - is only basic TOE “directional” adjustment (new car industry’s best kept secret).
Front Camber (and Caster) along with Rear Camber is now factory set to suit “Showroom Height” conditions.
Yet ongoing adjustment facility is essential allowing suspension to travel through required arcs and to be able to adjust tire contact angles when needed - to spread load more evenly. “Excess” edge load can also lead to ruptured side walls, rim damage.
Day to day commuting sighting (and being able to counter) “excess” passenger side edge wear through high cambered roads. “Excess” edge wear both sides through extra passenger loads or not offroading and deciding to lower vehicle height / roll center for safer handling. Fitting wide profile tires. Adjustment to counter curb knock damage.
SEE SPOILER - BOLT-ON ADJUSTER KITS ALL SUV’S INCL. AMG (W167, 166, 164, 163).
AUDI to VOLVO - Experience Resolving OEM Suspension Shortcomings (and costs) Since 1964 !
If having your car handle like a 90's F100 is the goal, just get a 90's F100.
