2022 GLS450 Needs an Engine replacement!
Honestly, if I were in your position, I'd get another car...
Think everyone would prefer a new car over an older one with a new engine, but that probably doesn't make much sense financially. Personally, would let them do the engine replacement and drive it for a bit. If no issues, show up, think you can feel good about having 20k less on the engine.
2. What did the dealer say is the cause of the oil leak? Where was the oil leaking out of the engine? e.g. What component failed?
Other than the open recall, all is "clean".
However, when looking at the detailed service records you see:
Something was clearly going on with the car. It was there in Feb for service, again in March (I think for just change out of snow tires back to summer tires), again in May, in June for the 10k service, and back in 2 weeks later. The only notes you see there are the "engine/powertrain computer module" checked and reprogrammed twice. No idea if that was all for one problem or a few. It was a certified Pre-owened with 4 years left on the initial + CPO warranties, and seemed to have no issues so I bought it. An engine replacement might not look that different (or it might say engine replaced, not sure). 2 years later, rock solid.
Either way, it is still definitely something to consider as some buyers will see it and be scared, but also think "normal enough" that some won't care, and suspect dealers won't care at all in trade (although I obviously can't speak for all dealerships).
Wonder if I went over to the BMW forum, created a name, and posted the same thing and then never came back.....
What exactly did the dealer say failed? Which internal part or seal?
thanks for sharing and keeping us in the loop!
However, I will say that is better than many other manufacturers would do. Many would want the technician to tear into the engine to make internal repairs or something other than putting an entirely new engine. I would say MB service is doing their best to completely solve the issue for you.
