Mercedes-Benz GLS Service Schedule
Is the schedule available somewhere as I am not able to find in inside the GLS Operator's Manual?
Interested into A,B services and intervals. Usually, other manufacturers put this information in the manual.
Also would DIY void the warranty i.e. oil / engine / air filters change?
Service Intervals (AMG, diesel and G-wagon will differ somewhat):
Oil & Filter (10k)
Dust Filter (10k) - if applicable
Cabin Combination Filter (20k)
Brake Fluid Flush (2 yrs)
Wiper Blades (2 yrs)
Engine Air Filter (50k)
Spark Plugs (50k)
Transmission Fluid and Filter (60k)
4MATIC Transfer Case Oil (60k)
Fuel Filter (120k)
Coolant (120k)
You are correct... Mercedes used to publish a "Maintenance Booklet," which included the required service intervals and all the items that the service tech is supposed to check at each service. At some point, Mercedes stopped including this booklet with new vehicles. The last one I've seen was for MY17. (If anyone has a Maintenance Booklet newer than MY17, please post it!) Since I haven't seen anything published after MY17, I've been relying on the MY17 intervals.
Interestingly, I noted a couple changes between MY14 and MY15, in that Mercedes reduced the spark plug interval from 60k down to 50k, and they reduced the transmission fluid/filter interval from 70k down to 60k.
Of course, you can always ask your dealer what they recommend, but then you're at the mercy of your service advisor's commission check for whatever services he wants to "recommend" (i.e. sell) you today...
I've attached the MY17 Maintenance Booklet here.
Hope this helps!
Oil & Filter (10k)
Spark Plugs (50k)
Fuel Filter (120k)
Coolant (120k)
Hope this helps!
Information inside is concise and right the to point. Addressing my concerns, manual says this:
The following cases are not covered by the Mercedes-Benz New Vehicle Limited Warranty:
- using engine oils and oil filters of specification other than those expressly required for the ASSYST PLUS service interval display.
- changing of oil and oil filter at change inter- vals longer than those called for by the ASSYST PLUS service interval display.
We strongly recommend that you have your vehicle serviced by your authorized Mercedes-Benz Center which is fully equipped to provide this service.
So bottom line is as long as certified parts are used, its all good. Of course the main message is to go to the stealership but I guess they are not allowed to say if u dont go there warranty is void.
@EWL5 Thanks for providing your thoughts as well.
