GLS Class (X167) Produced 2020 to present
"Quick Access" Dealer menu
Old Dec 20, 2023 | 12:31 PM
gln826's Avatar
GLS 550
On a 2024 GLS 450...
In this video, the author at the 5:50 mark talks about swiping left on the track pad 6 times while in the Settings app to access the Dealer menu:
I tried it on mine and it didn't work. A) Has anyone had success getting into it, and B) is there anything in there particularly worthwhile?
Old Dec 20, 2023 | 07:44 PM
W205C43PFL's Avatar
https://youtu.be/xr-pvouO6ms?si=Tb9lasAMYhjGQdWl
You have MBUX 2.0 (NTG7, myMBUX) so the method is changed, a forum member shared this, performed on a W223 with the same MBUX version just that it is the vertical style screen, but the method should be same, try it. HOWEVER, whatever you do NEVER restore to factory settings inside that menu, it will remove everything configured based on the options you equipped back to stock bare bone factory status meaning for example the rear view camera might not work etc it is not the same as just factory resetting MBUX.:
Here's that link, hope it works for the 2024 GLS 450: https://cimg5.ibsrv.net/gimg/www.mbw...37a1c21c51.png
