GLS Class (X167) Produced 2020 to present
Retaining Heated Seats
Old Jan 21, 2024 | 11:32 AM
DJBenzGLS's Avatar
GLS 580
Wondering if the 48V battery or accessory system can maintain some heated seat function while car engine not running? Don’t want to drain starter battery but would be nice to keep some seats warm while sitting in car.
Old Jan 21, 2024 | 03:52 PM
mikapen's Avatar
I'm pretty sure the seats (massage, heat etc.) are all legacy 12 volt.
As is the heater blower fan, but coolant is circulated through the system via a 48 volt water pump to keep the cockpit warm and windows defrosted. The AC (48v) will also kick in for defrosting.
The starter battery is actually 48 volt as well (ISG) but the car will restart if the batteries get too low.
Old Jan 21, 2024 | 04:01 PM
rockpool's Avatar
2024 GLS580
The 48v system replaces everything that used to be powered by a belt - the AC compressor, supercharger, water pump, power steering pump - If you take a look there's no belt-drive accessories on your engine. Plus it powers the starter motor.
Nothing else - everything else in the car is 12v still, including the heated seats.
48v simply allows the car to use smaller gauge wire and electrical motors.
Old Jan 22, 2024 | 01:25 AM
wyatt88's Avatar
GLS 450
Another poster mentioned that the A/C button if activated (it says 'rest' on the switch by the way), when the car is turned off, will allow the heating system to blow the residual heat from the engine. I have used this feature many times while dropping off and waiting for my kids during his practice sessions. The car is off but the heat keeps blowing. Works really well.
Old Jan 22, 2024 | 08:37 AM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
The 48v battery powers the ISG and the ISG starts the engine. The 48v battery is the "starter" battery. That said, the 12v battery still runs a lot of things that weren't transitioned over to 48v. There are also a number of systems in place to prevent the scenario you are describing. Keep yourself warm, the car will let you know if there is a problem.
While some of what you say is correct, the engine does not have a supercharger, and it does have a belt. The belt connects the ISG, crank, and AC compressor. Yes, the push to 48v is driven by the desire to reduce the amount of wires and wire gauge needed to power all the technology in cars. The last time this was done from 6v to 12v but that was in the 1950's. It is likely that everything will eventually transition to 48v or at least be able to have a 48v input but that will take a while.
Old Jan 22, 2024 | 07:42 PM
mikapen's Avatar
Old Jan 22, 2024 | 07:44 PM
mikapen's Avatar
There's also a 48 volt Supercharger in the 53s.
