GLS Class (X167) Produced 2020 to present
Updating maps
Old Mar 26, 2025 | 10:51 PM
ACC2's Avatar
GLS450
Updating maps
I'm having trouble updating installing the full map update which requires loading it on a USB stick.
What I tried:
Using the download manager, downloaded the 23gb update files onto a USB C stick (tried 2 different sticks)
Insert stick into lower dash usb ports
- not sure which is the right one, but I tried both the regular port and the CarPlay port several times
- turn on car and wait for prompt to install the updates which never comes
- I've verified the car can see the sticks, because I when I navigate to the music menu I see the stick's name as a USB source option
What am I doing wrong? Anyone had success with the most recent update?
Old Mar 27, 2025 | 05:31 AM
W205C43PFL's Avatar
What I tried:
Is the file format NTFS, not saying it is a requirement but worth trying.
Old Mar 27, 2025 | 11:50 AM
mikapen's Avatar
You might try the USB-C port in the armrest bin.
Old Mar 27, 2025 | 04:28 PM
TNS550's Avatar
2015 MB S550 & 2020 MB GLS 450
This is the one I use when updating maps.
Old Mar 27, 2025 | 06:21 PM
trigital's Avatar
W213 All-terrain
For NTG6 is clearly specified on DLM, is mandatory to be NTFS formated before uploading the Map.
Old Mar 27, 2025 | 07:15 PM
W205C43PFL's Avatar
I see, so that is OP's problem after all.
Old Mar 27, 2025 | 11:38 PM
W205C43PFL's Avatar
Clarification: I mean, as in the file format was the problem OP had after all.
Old Mar 28, 2025 | 07:55 AM
EWL5's Avatar
'23 GLS450
I think may of us knew what you meant but appreciate the follow-up!
Old Mar 28, 2025 | 09:47 AM
W205C43PFL's Avatar
I do apologize about the previous post, depending on how you read it, you might find it rude which wasn't at all my intention hence why I thought I had to clarify.
Old Mar 28, 2025 | 12:21 PM
mikapen's Avatar
Too bad we can't edit posts next day.
Clarification could be made in the same post to eliminate double confusion.
Old Mar 28, 2025 | 03:02 PM
W205C43PFL's Avatar
They removed the feature (as in editing after certain time) like last year as they said it is easier to moderate that way... apparently.
Old Mar 29, 2025 | 01:10 AM
mikapen's Avatar
Yeah I know but sometimes it makes for disjointed threads.
I'm all for making facilitators lives easier, so if that's the reason I'm fine with it.
Old Mar 29, 2025 | 08:20 AM
W205C43PFL's Avatar
I understand and I agree, it does. In an FAQ thread or log type thread, it also makes it much harder to organize information.
Old Mar 29, 2025 | 08:34 AM
W205C43PFL's Avatar
So the cutoff period for editing seems to be 240 minutes from initial post.
Old Apr 1, 2025 | 01:03 AM
ACC2's Avatar
GLS450
NTFS! Going to try this. Thanks!
Old Apr 1, 2025 | 07:20 AM
W205C43PFL's Avatar
Should hopefully do the trick : )
Old Apr 1, 2025 | 10:31 AM
ACC2's Avatar
GLS450
Ok, so the drives that I've tried are formatted exFAT, which I read should be compatible the Mercedes? Doesn't seem like NTFS is possible on a Mac.
Old Apr 1, 2025 | 12:04 PM
W205C43PFL's Avatar
If you read the previous posts, and if you have the pre-facelift GLS with NTG 6, you have to have NTFS format according to their post. Either get a windows computer or see if there is a program on mac that can format NTFS for you.
