Climate control for middle row
My first MB ever - so not sure if this is normal?
The rolling knob on each of the rear vents is not a mechanical one. They have a sensor that will later adjust AC air flaps electronically to direct the distribution of flow through the air ducts. It's possible that these knobs are no longer sending a signal to adjust the air flaps. This is all separate from the AC fan speed.
Air flow fan speed is adjusting through the AC settings, but the flaps opening/closing % is electronically adjusted by those knobs on each of the vent. They look mechanical by they are not.
Air flow through 2nd and 3rd row AC vents is more than excellent. Much better than any other SUV I've seen.
