Need New Taillight
#167-906-3007
#167-906-3607
Are they plug and play? Do I need coding after installation? My tailights work fine just the back up light on the right side of the car doesn't work.
Hint: disconnect the negative from the battery first before you remove the existing lighting modules, otherwise you might get a permanent error in the form of engine light that needs Mbenz software/hardware to clear up. I had this issue when I disconnected the passenger seat, which triggered an air-bag message, and it I had to ask Elebest to clear it up for me.
Airbag is in the seat, once disconnected it will trigger airbag check light in cluster. Taillights are just some LED lights. If you can do some soldering work, you can try to fix it by replace one or some LEDs.
