GLS Class (X167) Produced 2020 to present
Aftermarket 22x10 wheels: offset choices and sources?
Old Feb 12, 2026 | 12:08 PM
truckin-on's Avatar
GLS580 on order
New 2026 GLS580 w/ staggered 22 wheels w/ summer tires being delivered in a week or so. I want to go to a square 22" all-season setup w/ 22x10 wheels. I like the AMG-style wheels, black with machined lip, and have found these with ET40, 42, and 48 off-set. With the ET48, looks like 20mm inset on the rears, so the addition of a 15mm spacer would put them back to "normal." Any thoughts on which of these choices would be better? Not much difference I know, but worth asking. Anyone have good/bad experiences with these aftermarket wheels, and/or purchasing from a wheel vendor? Here's three choices I've found so far:
https://www.elitecustomrims.com/prod...4b643ae4&_ss=r
https://www.ebay.com/itm/256045895021
https://autocustomz.com/collections/...in-blackwheels
For reference, found a good visual offset calculator here: https://jr-wheels.com/et-calculator
Thanks for any opinions!
Old Feb 14, 2026 | 11:21 PM
truckin-on's Avatar
GLS580 on order
Ordered a set of 22x10, ET40 from Elite Custom Rims - they were very responsive with questions, so we'll see what they look like when they show up. I'm going with a set of Pirelli Scorpion WeatherActive in 285/45R22, and 4 new TPMS sensors. Total cost a bit over $3k.Sure would have been nice to just order the car this way! The staggered set of wheels/tires will go on the shelf for now...
Old Feb 15, 2026 | 09:17 AM
EWL5's Avatar
'23 GLS450
If it could be ordered that way straight from factory, then it wouldn't be so obvious that Mercedes is also having trouble sourcing 22" and 23" all-season tires!
Old Feb 15, 2026 | 03:39 PM
truckin-on's Avatar
GLS580 on order
Interesting also that for the staggered setup, the tire mileage warranty is de-rated by 50%: "6 Years / 60,000 Miles 50% mileage for rear if different size than front". Not that it's worth much anyway, but still...
Old Feb 19, 2026 | 06:52 PM
truckin-on's Avatar
GLS580 on order
Next chapter... The 22x10 wheels showed-up this afternoon - they are huge and heavy! And to no great surprise to me they are actually ET48, not the ET40 advertised or confirmed by the seller! Argh. Not a big deal, and what I was expecting based on the part number, but still disappointed in the lack of reliable information. So I proceeded to order a pair of H&R 23mm spacers from here:https://www.vividracing.com Total delivered ~$250. The "Mercedes" caps that came with the wheels are a bit cheesy, as are the stick-on AMG logos, but I can live with that. Otherwise, the wheels look really nice!
With the spacers on the rear, and the 20x10 ET48 on the front, will end up with both F&R about stock looking: +3.5mm front, +3mm rear, from stock staggered, so close enough for me. Now on to tires and TMPS!
Old Mar 9, 2026 | 12:08 AM
truckin-on's Avatar
GLS580 on order
And now, the rest of the story...
Wheels arrived, tires arrived (Pirelli Scorpion WeatherActive in 285/45R22), OEM quality TPMS from RockAuto, tires mounted and balanced, and no real surprise other than can't use OEM lug bolts! First set from Amazon too long by 3-4mm, next set correct - about 19mm of thread extended into the hub. Installed H&R spacers - quality product! Caution - you will need a thin-wall 17mm socket to be able to get full contact on the spacer to hub bolts! Happy with the final look. The ET48 rims, with the H&R spacers look completely stock, and have the rims within 3mm of the OEM setup. TPMS sensors no problem at all. Happy with the look of these wheels - sorry, it was a crappy day so it was dirty and wet when picture taken :-)
