W211 armrest
I have a w211 arm rest for sale 200 plus shipping. The wood grain I had vinyl wrapped in black but I can remove it before I ship if you want.
http://i1088.photobucket.com/albums/...B73479DC13.jpg http://i1088.photobucket.com/albums/...B73158B79F.jpg http://i1088.photobucket.com/albums/...B72D31BDCF.jpg http://i1088.photobucket.com/albums/...B72865B68B.jpg |
What color is the wood grain underneath?
damn! Was hoping it was birdseye :*(
That's why I vinyl wrapped it
Mark, got instructions on to remove/install the armrest? Been looking for that.
Originally Posted by geecee
(Post 5431711)
Originally Posted by Craftysince86
(Post 5432061)
it's a really easy install, only thing is if you are upgrading from the clam shell the harness' aren't the same and you throw an SOS error
I can't seem to find the screw points, so was wondering if anyone had instructions on how to remove/install. Or at least pointers on how to get to the appropriate screws. Thanks. |
(Post 5432073)
Thanks Crafty. Am trying to remove a broken armrest with similar design, sliding cover. Don't have a clam shell. Want to see if I can fix it easily.
I can't seem to find the screw points, so was wondering if anyone had instructions on how to remove/install. Or at least pointers on how to get to the appropriate screws. Thanks. and then when you open the actual arm rest, remove the cup holders and remove the bottom lining of the arm rest and there is more under there i can't remember how many are under there though :confused: |
(Post 5432130)
the whole ash tray assemble has to come out, there are 2 screws under there...
and then when you open the actual arm rest, remove the cup holders and remove the bottom lining of the arm rest and there is more under there i can't remember how many are under there though :confused: It's an '08 E350. Can't seem to pull out the ash tray assembly without some force, so am not sure if that's right. cup holders removed. suggestions to remove bottom lining? this should be a relatively simply procedure, as long as you know the exact process which is the trick. cheers. |
(Post 5432061)
(Post 5432570)
Thanks again Crafty. Sorry to be such a noob!!
Originally Posted by mikey33
(Post 5433232)
Hey! What did you do to remove the SOS error?
GL fellas! |
2 Attachment(s)
I found it difficult to release the rear of the console until I found the clips that needed to be pushed in. I've attached a couple photos of the clips and screwdriver used to depress them.
150 plus shipping
Or make me an offer. I need it gone
would the rear climate controls still work when coming from a clamshell? What from the harness wont connect?
