C55 vs. M3 (E46)
and all that rambling about perfect shifts everytime being said, it still loses to the C 55 which is using the standard "auto" mode
BTW cldriver, what was the trap speed of those 1/4 mile times you saw, 13.7 is significantly slower than the published numbers I've seen. I always heard 13.2
God I hope a 350+ hp 350+ lb/tq V8 beats a I-6 that makes 333hp and 278 lb/tq. Not a fair race ... not fair either to compare 3.2 liters to 5.5 liters, also lets not mention the M3 came out in 02 and your C55 came out in what 05. The difference between SMG and your C55 transmission is night and day, again SMG does not have a torque converter that your C55 has.. I am not even going to bother to explain it you need to go read about it...
Here go read about http://auto.howstuffworks.com/sequential-gearbox.htm
SMG
Then go read about an auto transmission that a C55 has
http://auto.howstuffworks.com/automa...ansmission.htm
SMG
BTW, 6-speed stick shift is the only way to roll on an M3.
Seems like it happened since the forum upgrades. Who are you and what have you done to Ricky?!
